Page not found (404)
Request Method: GET
Request URL: http://www.jammaplus.co.uk/forum/forum_posts.asp?TID=73413&PID=741019&title=pc-engine-rgb-amps
Using the URLconf defined in web_v3.urls, Django tried these URL patterns, in this order:
  1. delete_event/<int:event_id>/<int:device_id>/ [name='delete_event']
  2. admin/
  3. ^accounts/login/$ [name='core.views.login_view']
  4. ^accounts/logout/$ [name='core.views.logout_view']
  5. ^accounts/profile/$ [name='core.views.profile_view']
  6. ^devices$ [name='core.views.devices_view']
  7. ^devices$ [name='core.views.devices_view']
  8. ^device/(?P<device_id>\d+)/setup$ [name='core.views.device_setup']
  9. ^device/(?P<device_id>\d+)/setup/name$ [name='core.views.device_setup_name']
  10. ^device/(?P<device_id>\d+)/setup/input/(?P<input_id>\d+)$ [name='core.views.device_setup_input']
  11. ^device/(?P<device_id>\d+)/monitor$ [name='core.views.device_monitor_view']
  12. ^device/(?P<device_id>\d+)/monitor/core$ [name='core.views.device_monitor_core_view']
  13. ^device/(?P<device_id>\d+)/history$ [name='core.views.device_event_history_view']
  14. ^locations$ [name='core.views.locations_view']
  15. ^location/add$ [name='core.views.location_mod_view']
  16. ^location/(?P<location_id>\d+)/mod$ [name='core.views.location_mod_view']
  17. ^location/(?P<location_id>\d+)/setup$ [name='core.views.location_setup_view']
  18. ^location/(?P<location_id>\d+)/setup/input/(?P<input_id>\d+)$ [name='core.views.location_setup_input_view']
  19. ^contact-groups$ [name='core.views.contact_groups_view']
  20. ^contact-group/add$ [name='core.views.contact_group_add_view']
  21. ^contact-group/(?P<group_id>\d+)/setup$ [name='core.views.contact_group_setup_view']
  22. ^contact-group/(?P<group_id>\d+)/setup/name$ [name='core.views.contact_group_setup_name_view']
  23. ^contact-group/(?P<group_id>\d+)/del$ [name='core.views.contact_group_del_view']
  24. ^contact-group/(?P<group_id>\d+)/add_contact$ [name='core.views.contact_group_setup_add_contact_view']
  25. ^contact-group/(?P<group_id>\d+)/del_contact/(?P<contact_id>\d+)$ [name='core.views.contact_group_setup_del_contact_view']
  26. ^contact-group/(?P<group_id>\d+)/edit_contact/(?P<contact_id>\d+)$ [name='core.views.contact_group_setup_change_contact_view']
  27. ^tc65$ [name='core.views.devicecomm_tc65_view']
  28. ^tc65CmdAck$ [name='core.views.devicecomm_tc65_cmdack_view']
  29. ^doc/description [name='core.views.doc_description_view']
  30. ^about$ [name='core.views.apropos']
  31. ^$ [name='core.views.index']
The current path, forum/forum_posts.asp, didn’t match any of these.
You’re seeing this error because you have DEBUG = True in your Django settings file. Change that to False, and Django will display a standard 404 page.
